lowering my mk 6 escort van
Old May 10, 2008 | 06:44 PM
zippyka80's Avatar
zippyka80
Default lowering my mk 6 escort van
i have a mk 6 van i was wondering how the best way to lower it as it has leaf springs on rear
Old May 11, 2008 | 01:35 PM
gup's Avatar
gup
ive lowered my van by putting the leaf springs under the rear beam instead of having them sitting on top of the beam
Old May 11, 2008 | 01:38 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Just get a fat mate to live in the back.
Old May 11, 2008 | 11:22 PM
vinnyvangough's Avatar
vinnyvangough
As said, put the leaf springs underneath the axle. cut the bump stops too!!!!!!
Old May 13, 2008 | 08:12 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
You used to be able to get decambered springs from Leda.
Old May 14, 2008 | 05:11 AM
There are still firms around that offer a decambering service on the leaf springs.
Old Jun 13, 2008 | 07:24 PM
davidfox280585's Avatar
davidfox280585
i have looked as i have a mk5 and they are twin leaf springs and cannot see how it is possible to fit them underneath as i have done a mk4 but mk5s and 6s are different any help
Old Jun 13, 2008 | 11:19 PM
vinnyvangough
They will fit underneath, you should get a set of lowering blocks too. The original u-bolts can still be used.
Old Jun 14, 2008 | 10:32 PM
davidfox280585
what about the brackets ive heard i have to reweld the mount brackets underneath
Old Sep 28, 2009 | 06:49 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
I cant see how you would need lowering blocks aswell as putting it under the axle ! Putting the springs under the will lower it by at least 70 to 80 mm anyway ! Plus the brackets you will need to re locate are the ones for the dampers ! As you need to flip the axle over so you can locate the springs still to the same place ! Thus needing to re locate the brackets ! Hope this helps !
Old Sep 28, 2009 | 07:22 PM
mercury grey minter's Avatar
mercury grey minter
Any pics as i need to do this to my TRANSIT CONNECT (Similar set-up)
Old Sep 28, 2009 | 10:48 PM
ianmexico's Avatar
ianmexico
i done my m8s caddy van which is pretty much the same as my connect and cut off spring saddles welded them on directly opposite where they were mounted then fitted springs on opposite side of axle easy afternoons work was thinking of doing connect too only other thing is connects have droplinks on back axle aswell
Old Oct 14, 2009 | 12:45 PM
owensprings's Avatar
owensprings
alrite im from a company in rotherham who make leaf springs if you want i can sort you out by lowering you leaf springs or i can sort you out with new ones lowered to what you want intressed give me a ring on 01709710700 or drop me an email
Old Oct 14, 2009 | 05:56 PM
Roscopeco's Avatar
Roscopeco
How much would it be to lower my springs by say 60mm ?
Old Oct 15, 2009 | 07:36 AM
owensprings
alright fella
you would need to get them to me and it will cost you Ł40.00 each + the carriage to get them back to you which will be around Ł20 any chance of a pic of the springs or tell me how many leaves there are in the springs?
Old Oct 15, 2009 | 08:36 PM
Roscopeco's Avatar
Roscopeco
Ok mate well i'll take a pic over the weekend and post it up on here ! How long would it take you to do them as i need the van for work so would need it doing asap really ! Im based near leeds so can drop them off and collect to speed things up !
Old Oct 15, 2009 | 10:53 PM
owensprings
as long as its early enough can get it ya done in the day part from fridays
Old Feb 24, 2012 | 11:34 PM
leedsrhinos126's Avatar
leedsrhinos126
Hi mate i know it's a couple of years on but did you get round to getting the leaf spring de-cambered or new lowered ones? If so how much ?
Thanks
Ryan
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Mxkid
Aug 31, 2015 10:02 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
