Frst wont start
Old Oct 24, 2004 | 10:12 PM
chubbs358's Avatar
chubbs358
Default Frst wont start
the story so far
I got a flat battery the other day so I took it off charged it put it back on but now The car turns over like normal and evrything works, fule pump primes ect the car just wont fire so took a ht lead off and put a multi-meter on and my brother turned it over and i got no voltage at all. i have check conections as best i can, all fuses and i took the ecu out and checked conector and pins all clean and none burnt but i didnt take it apart im not that brave.
what next? i was thinking i should get the ecu and coil/distributor thingy tested?
Any help apreciated
Mark
Old Oct 25, 2004 | 12:23 AM
b13nde's Avatar
b13nde
try the flywheel sensor some times the loom burns from the heat or lose as it come from the chassis to a moveing engine
Old Oct 25, 2004 | 10:27 AM
chubbs358's Avatar
chubbs358
thanks i will go and check that out
Old Oct 25, 2004 | 08:02 PM
chubbs358's Avatar
chubbs358
im happy and p!ssed off at the same time th cars working now but now i have a problem that dosent exist to find
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
kevin36
Sep 2, 2015 06:24 PM
