Temp Sensor
Old Oct 22, 2004 | 04:43 PM
K18NEO's Avatar
K18NEO
Default Temp Sensor
Start my car (S2 RS TURBO) and the temp shoots rite to the top.
Now, when the car actually gets hot, the fan cuts in and alls well.. so whats making it go right to the top>
Old Oct 22, 2004 | 05:08 PM
davidnormanuk's Avatar
davidnormanuk
Could be a bad connection. If you earth the wire that goes to the temp sender, it makes the dial go right up or it could be a faulty sender.
Dave
Old Oct 22, 2004 | 05:12 PM
K18NEO's Avatar
K18NEO
thanks alot!
Dave Henshall's Avatar
Dave Henshall
usually full scale is short circuit to earth, so either the sensor has failed, or the wiring to ti is shorted down to earth somewhere - a quick check... if u unplug the cap off the end - does it go down..., if not , then its more than likely the loom.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
