vacuum test
Old Apr 4, 2008 | 02:42 PM
RS SHAUN's Avatar
RS SHAUN
Default vacuum test
Having problems with my 2wd saph overfuelling, i've sent the ECU off to get tested because the CO screw doesn't seem to work, we've done a compression test and that was fine. We also done a vacuum test on all 4 cylinders and we were loosing 30% on cylinders 2 & 3, is this a lot??? All the sensors have also been changed.
Old Apr 5, 2008 | 09:26 PM
Bubs's Avatar
Bubs
You shouldnt loose that much vaccum. 30% is quite a lot.
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
hopper350
Sep 4, 2015 12:53 AM
