Garrett GT2871R on a 4x4 sapp cossie
hi guys, we are trying to choose a new turbo for a mates car, looking for 360-400 bhp.
the engine is standard at the moment, apart from the usual stage3, moongoose and a cone-filter.
std compression, std intercooler, std head, std inlet manifold and a 2wd exhaust manifold.
the inlet and intercooler is most likely to change in a short time, the inlet is gonna be changed to a jenspeed re-welded inlet, with the elbow enlarged. the head will be ported when the standard headgasket lets go.
we would really like to test a good garrett gt-turbo, and at first the gt3071r was considered, but we have now looked more at the gt2871r with an .63 turbine-house and a t3-flange. used along with a -31 actuator and a good bleed-valve.
what do you guys think about this?
does anyone have any experience with this turbo, or a gt-turbo of similar-size?
Except the one you just posted
I think leecavturbo on here has a gt2876r on his car...with very good results....I was thinking of using one of these on my build but a t34.63 setup has come about which will cost me a lot less so i've gone for that.
Dan
but your forgetting that the gt28 (dependant on a/r) can flow enough for arround 400bhp.....whereas the T3 will do ~100bhp less...
So if it has same drive feel but can produce 10bhp more then it can't be bad.
Dan
Dan
Russ Payne
25-09-2015 09:29 PM
