turbo stall
Old Feb 3, 2008 | 07:32 PM
wimble's Avatar
wimble
Default turbo stall
how do you stop turbo stall
Old Feb 3, 2008 | 10:10 PM
mechanic28's Avatar
mechanic28
in what way?when boosting up?or when backing off?if when backing off fit a dump valve if u aint got one fitted
Old Feb 4, 2008 | 09:00 AM
wimble's Avatar
wimble
when boosting up
Old Feb 4, 2008 | 02:26 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
by limiting the boost, or running a different spec of turbo / engine
Old Feb 4, 2008 | 04:55 PM
mechanic28's Avatar
mechanic28
turbo surge then there a several things u can do get it mapped up,get a turbo with cut back blades on the exhaust sides!your turbo it pushing to much volume of air into your engine thus causing it to stall
Old Feb 5, 2008 | 06:19 AM
You don't cut the Turbine blades, you cut back if necessary the Compressor blades.
IF it is stalling and causing surge then most likely cuplprit is too large a compressor in relation to the turbine size.
What spec is everything ?
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
