COSWORTH 4X4 PROPSHAFT DONUT
DOES ANY1 KNOW WHERE CAN I FIND ONE THERE IS A BEARING THAT SITS INSIDE AT THE BACK OF THE BOX AND THE END OF THE PROP
THANKS IN ADVANCE
THANKS IN ADVANCE
I have got 1 that i was gunna use on my saff but never fitted it . Its the 50p shaped 1 with the bearing in the middle is that the one you are after ?
Depends which one it is that you need.... the 4x4 saff ones with the bearing in the middle are no longer available from ford
Cossiemodo
Anutternutter
21-08-2015 06:07 PM
charliecosworth
19-08-2015 02:00 PM
