escort series 1 +2 gear box ratio
wat the fuck
hi... i just found out that the esort s1 gearbox ratio is lower than the s2 but will it still be just as fast on top end...thank you
No it won't, unless you have standard 132hp. Don't think anybody has nowadays. The S1 ratios are quite bad for everyday driving on the whole as far as I am asked. Quite many are going the opposite way and changing to Diesel's 3.54 ratio like I did too. Also saves nearly 15% petrol.
