Alternator on sierra cos
Old Oct 12, 2004 | 06:55 PM
simonc's Avatar
simonc
Default Alternator on sierra cos
I have a 3dr cos & it needs a new alternator, are they the same on 2wd & 4x4 saph & 3dr, are they the same as a boggo sierra ?
Thanks Simon.
Old Oct 12, 2004 | 08:14 PM
Alvyn's Avatar
Alvyn
Default Re: Alternator on sierra cos
Thanks Simon.
3dr and 2w/d saff are the same late 4x4 and boggo sierra R not
Old Oct 12, 2004 | 10:18 PM
ian sibbert's Avatar
ian sibbert
Got a cheap 90amper matey p.m. me if you r interested...
regards
ian
Old Oct 13, 2004 | 07:31 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the mounting is the same as any boggo pinto, but the current rating is higher for extra ancillaries like front fogs, heated windscreen etc.
4x4 went to a poly-vee belt drive rather than the twin belt of the 2wd models.
Old Oct 13, 2004 | 10:13 PM
simonc's Avatar
simonc
Thanks peeps.
Simon
Old Feb 13, 2005 | 01:35 PM
Mad Matt's Avatar
Mad Matt
Rally nut
So if I have a 1990 Sierra Cosworth 4x4, can I put a standard Ford Sierra alternator ? Mine is dead.
Old Feb 13, 2005 | 06:20 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you can. you may have to change the pulley over, and it probably wouldn't last very long if you put full load into it (used all of your electrics like headlights, heater motor, radiator fans) as you would be trying to get more current from it than it can produce. you can't damage anything except the alternator itself though, unless your fuel pump also gets a low voltage due to too much current draw and then you could melt the engine as the pump won't be able to supply enough fuel.
best get a proper one eh?
Old Feb 15, 2005 | 06:07 PM
Mad Matt's Avatar
Mad Matt
Rally nut
Yes I guess so. I'm trying to watch around me to see if I can get one, but 1 door has been closed today unfortunetly. Some still are open and I'm waiting, but I can't wait to hear again the sound of my catalysed Cossie !
Old Feb 15, 2005 | 08:33 PM
bigal1978's Avatar
bigal1978
i tho the sierra xr4x4 was the same as a 2wd 1
Old Feb 16, 2005 | 10:21 AM
foreigneRS's Avatar
foreigneRS
Testing the future
it could be Al. all you need is the right mounting and the right current capability (90A on a 4x4). some look the same but aren't quite as the front housing is 90 degrees out, but that can be rectified by unbolting it (if you can get them undone - impact drive usually necessary), and you can swap pulleys over.
jonfoc
16
Sep 11, 2018 05:35 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
jay030787
Sep 18, 2015 04:38 PM
gcfcos
88
Sep 15, 2015 03:48 PM
cossie09
Sep 10, 2015 06:56 PM
