ford escort turbo diesel running problems
Old Dec 25, 2007 | 09:11 PM
ceri.demarco's Avatar
ceri.demarco
Default ford escort turbo diesel running problems
hi can anyone help i,ve got a 2000 ford escort turbo diesel it,s running like it is sucking in air i put a new air mass meter on but it made no difference but i noticed the wireing block that is plugged in to the meter does not make any difference if it is connected or not it still runs the same does anybody no what that plug should do or do they have any suggestions what it could be thank you
Old Dec 25, 2007 | 09:15 PM
gkandr4ch's Avatar
gkandr4ch
Have you got an air filter in the box?
Old Dec 25, 2007 | 09:18 PM
ceri.demarco
yes fitted a new one
Old Dec 26, 2007 | 04:09 PM
phill295's Avatar
phill295
i would then check for air leaks on all the rubber hoses as they become weak with age and can colapes.
i have replaced the turbo to air box pipe on several vans as it becomes porus at the turbo and did not fit correctly.
hope it helps
matman
Sep 9, 2015 05:45 PM
taylora1409
Aug 12, 2015 12:06 PM
ginger1979
Jul 31, 2015 09:56 PM
