Oil Catch Tank
Old Dec 24, 2007 | 04:40 PM
woolford's Avatar
woolford
Default Oil Catch Tank
Hi is an Oil Catch Tank for the same purpose as an oil breather????
Old Dec 25, 2007 | 07:55 AM
NO, a breahter is just that it allows it to breath, a catch tank holds ther fumes and allows them to de aerate so that you get the oil saved, a lot are combined breather/seperator, with a catch tank in the bottom.
Old Dec 25, 2007 | 08:14 PM
mikee_rs's Avatar
mikee_rs
i have a mocal catch tank which has a breathable cap
Old Dec 26, 2007 | 01:39 PM
woolford's Avatar
woolford
can some1explane in idiot turms as i dont have a clue why or what i would need one for??
Old Dec 26, 2007 | 03:42 PM
richard_syko's Avatar
richard_syko
You have a breather which allows the crankcase (inside the block) to be vented. Otherwise, when you have blow-by gases (the air/fuel that goes beside the piston rings) the block would build up pressure and eventually crack.
This breathing sometimes allows oil to escape aswell as air, mostly at high RPM and high LOAD times.
If this oil kept escaping you would spend a fortune on oil, so you catch it and most of the time allow the oil and air to seperate and the oil to drain back to the block, the air to be vented.
Old Dec 26, 2007 | 04:34 PM
Wot he said!!
Old Dec 27, 2007 | 08:51 AM
woolford's Avatar
woolford
thankyou...
155lee
Oct 27, 2015 04:55 AM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
