Escos big turbo plenum info needed
Old Dec 21, 2007 | 04:01 PM
allsteel's Avatar
allsteel
Default Escos big turbo plenum info needed
What goes to what on the 4 pipes near the brown sensor on the back of the plenum.I have the fuel reg going to the front one and the one below the sensor has been blocked off.What goes to the other 2.Running anti lag if that helps.
Old Dec 22, 2007 | 01:31 PM
allsteel's Avatar
allsteel
Big up cos it's effin cold in the garage.
Old Dec 22, 2007 | 05:52 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
On my 2wd the re was 1 to the map sensor, 1 to the fuel pressue regulator and I cant remember where the other one went boost gauge?
Old Dec 22, 2007 | 08:05 PM
allsteel's Avatar
allsteel
Problem is it's on a Puma with Cosworth running gear and i sold the original plenum.The fuel line comes through the bulkhead and is next to the regulator but theres a tricky little fitting with a screw on braided hose and i dont know what it is.By the length of the pipe it goes to one of these outlets but as the ends are different i dont know which one.Take it from me,when a car has been stripped down and nothing marked cos you thought you were breaking it's a big ask putting it all back.Nearly there though.
cos elle
Sep 1, 2015 06:48 PM
james kiely
Aug 28, 2015 08:58 PM
col93saphcos
Aug 7, 2015 03:21 PM
Blown Hell
Aug 5, 2015 07:22 AM
Escortdriver1
Jul 31, 2015 02:36 PM
