CAM TIMING USING VERNIER PULLEYS.
Old Dec 18, 2007 | 06:08 PM
G 74F 00's Avatar
G 74F 00
Default CAM TIMING USING VERNIER PULLEYS.
DOES ANY ONE KNOW HOW TO SET UP THE CAM TIMING USING VERNIER PULLEYS? HAS ANY ONE ATTEMPTED THIS THEMSELFS BEFORE?
IM USING BD10 CAMS IF THIS HELPS?
THANKS!
Old Dec 19, 2007 | 06:04 AM
Easy, you will need a degree disc(ideally) but defo a dial gauge.
You will have the cam timing figures, so set up dial g on cam and get full lift where it says by adjusting, do this to each cam then just lock off.
Old Dec 19, 2007 | 08:01 AM
2001ode's Avatar
2001ode
Hi,
You can found a very good explanation in Burton Power catalog, on page 4.
Regards.
Claude
Old Dec 21, 2007 | 06:56 PM
mappindude's Avatar
mappindude
another way is lift on each cam at tdc.
Old Dec 21, 2007 | 07:02 PM
rapidcossie's Avatar
rapidcossie
We messed around on the rollers til the power was where we wanted and was at its peak
RUBY123
Oct 22, 2023 12:04 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
