200 block cossie core plugs
Old Dec 12, 2007 | 08:53 PM
stumpy's Avatar
stumpy
Default 200 block cossie core plugs
help please!
I have removed all the core plugs out of my 200 block. Ihave been to fords and have managed to replace all the big ones but there are 2 small ones on the front behind the aux shaft plate that fords can not find on there computer. They also show a large core plug behind the flywheel which my one does not have.
Any help will be great thanks
Old Dec 12, 2007 | 09:03 PM
PGT's Avatar
PGT
i think you mean the oil gallery plugs?
try burtons
Old Dec 12, 2007 | 09:05 PM
stumpy's Avatar
stumpy
thanks will give them a call tomorrow
Old Dec 13, 2007 | 01:35 AM
jon@work's Avatar
jon@work
there are 3 sizes of oil gallery plugs listed, as follows :
11mm diameter by 4 deep,finis 0241510
14 x 5, finis 1454265
15 x 5, finis 1517888
measure your block to determine which you need
the large plug was not used/required on later blocks
Old Dec 14, 2007 | 05:15 PM
stumpy's Avatar
stumpy
thanks for that all sorted now.
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
gcfcos
Sep 11, 2015 06:03 PM
