cosworth abs
Old Dec 10, 2007 | 03:15 PM
jabcos's Avatar
jabcos
Default cosworth abs
i've got a 4x4 cosworth and i was just wondering if it's all right to take the abs off and just run with standerd brake master cylinders
Old Dec 10, 2007 | 05:40 PM
My mate has a 4x4 cossie and he said his abs is nackered on his car. He said he was gonna just take it all out and put a normal system in.
Old Dec 11, 2007 | 07:39 AM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
which bit is broke, replacement bits are cheap as chips on ebay, it could be the controller which is a quick swap...cost only a few pounds and could solve it.
Dan
Old Dec 11, 2007 | 11:09 AM
jabcos's Avatar
jabcos
aim just looking to take mine out for more room but aim not shore if it will work alright with big brakes
Old Dec 11, 2007 | 12:34 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Bear in mind with a 'standard' servo it's got only a tiny percentage of the assistance provided by the electro-hydraulic Teves system that's there already.
Also, if you remove it, you'll have to stick it back on, and make sure it works come MOT time, unless you have a 'friendly' tester...
If you've got a problem with it, it's worth tracing and fixing the fault purely so that your ABS works. I have several guides for testing/diagnosis on the Teves mk2 system - let me know if you'd like a copy.
Old Dec 11, 2007 | 05:28 PM
For the mot if the abs system isnt there to test and its got a normal servo it will pass.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
