Red Weber TPS Cosworth Question!
Old Dec 9, 2007 | 06:53 PM
Rupean's Avatar
Rupean
Default Red Weber TPS Cosworth Question!
Does anyone no what signal, 5v and earth is in 1.2.3 order on red weber cosworth trottle position sensor?
Old Dec 10, 2007 | 06:30 AM
Rupean's Avatar
Rupean
bttt.
Old Dec 10, 2007 | 08:38 AM
BMEP's Avatar
BMEP
Not sure about the 1, 2, 3 order however the wires on the plug to the TPS are....
Red wire (ecu pin 30) is the 5 volt feed to the TPS, the Black wire with Red stripe (ecu Pin 17) is the signal (Centre pin on TPS) back into the ECU and the Brown with Green stripe (ecu Pin 11) is the Earth supply to the TPS.
Old Dec 10, 2007 | 10:16 AM
What he said!!
Anutternutter
24
Aug 31, 2015 01:24 PM
muz
Aug 16, 2015 12:57 PM
Roosie
Aug 15, 2015 08:09 PM
markk
Aug 15, 2015 01:38 PM
Aug 14, 2015 07:29 AM
