IB5 BOX
Old Dec 8, 2007 | 04:52 PM
Barry R's Avatar
Barry R
Default IB5 BOX
Daft question
What car can i find 1 of those in?
Old Dec 8, 2007 | 04:58 PM
bookwyse's Avatar
bookwyse
Any fwd Ford from the MK3 escort upwards, fiesta to around `1997, orion
Old Dec 8, 2007 | 05:00 PM
Barry R's Avatar
Barry R
thought so CheeRS Buddy
Old Dec 8, 2007 | 05:03 PM
Barry R's Avatar
Barry R
any 1 got any cases for 1 a mk3 escort just the cases
Old Dec 9, 2007 | 09:21 PM
JesseT's Avatar
JesseT
You're confusing it with the BC gerbox. The IB5 came around ´95 and is still in use AFAIK.
Old Dec 10, 2007 | 08:32 AM
bookwyse's Avatar
bookwyse
Hmmmmm, IB5 hasnt been used since the MTX75 box came out which is to be found in the very late Escorts, All Focus's and all Mondeos.
The BC box is basically the same as the IB5 but without a gate in the box and a smaller welded clutch arm.
Also the later typer IB5 have a larger main shaft bearing.
Some of the early BC's also had a four bolt bracket for mounting whereby the later ones use a full crossmember.
Trust me, I used to rebuild them for a living.LOL
Old Dec 10, 2007 | 10:11 AM
Barry R's Avatar
Barry R
so which 1 would be best for a s1 turbo
Old Dec 10, 2007 | 11:28 AM
bookwyse's Avatar
bookwyse
Does it have a four bolt mouting or a cross member? Also does it have a welded or bolt on clutch arm??
Old Dec 10, 2007 | 07:16 PM
Barry R's Avatar
Barry R
4 bolt mounting with bolted clutch arm
Old Dec 10, 2007 | 08:02 PM
JesseT's Avatar
JesseT
The gated version is also BC. MTX didn't replace the BC or IB5. It was only used in higher powered models. I have an IB5 in my Focus for example.
http://www.burtonpower.com/technical...5_gearbox.aspx
http://www.burtonpower.com/technical...c_gearbox.aspx
Old Dec 11, 2007 | 07:13 PM
Bungle's Avatar
Bungle
And i have an ib5 in my escort gti
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
