Turbo Core can you crack it, water in exhaust system?
Get on That!
Just reading on another post and i always wondered can you get the turbo that hot that it would crack and cause water that flows round the core to leak into exhaust housing?
But thus causing no ill effect to the running of the car or damage to the seals & bearing on the turbo shaft?
or is this impossible and if the core cracked enough to let water get into the exhaust system it would also damage the shaft, seals & bearing?
Get on That!
not too sure Matt, but can you not just dsable the water supply to the turbo and then go from there.
(This ain't a problem i'm having) Just curious thats all
Matt Baxter
16-09-2015 08:30 PM
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
blakey100
04-08-2015 08:17 PM
