Sierra Cosworth
Old Dec 2, 2007 | 09:42 PM
RS Essie's Avatar
RS Essie
Default Sierra Cosworth
my friends cosworth wont boost over 0.8 bars (cossie have chip and 350 HP)
sorry on my bad english (i am from croatia)
Old Dec 2, 2007 | 09:45 PM
rapidcossie's Avatar
rapidcossie
possible air leak?
Old Dec 3, 2007 | 04:59 AM
stevecossy's Avatar
stevecossy
As above also i take it he has a 3 bar map sensor fitted if running 350 bhp
Old Dec 3, 2007 | 07:38 AM
J9BBY's Avatar
J9BBY
If he is using an amal valve to control the boost is this jetted correctly?
Old Dec 3, 2007 | 08:44 AM
Just remove the restrictor valve on the amal, pull it out completely.
Old Dec 8, 2007 | 06:38 PM
RS Essie's Avatar
RS Essie
sierra is running on 2 bar map sensor and manual boost controler, there is no air leaks
btw. problem are started after remaping ECU before that sierra was running with 280 PS on 1,5 bars without problems
and this remaped ECU works on another sierra without problems
Old Dec 9, 2007 | 06:50 AM
Speedy G.'s Avatar
Speedy G.
Sounds like he is running his original MAP sensor and I think that the remapped ECU needs a 3bar MAP sensor.
Go and see what the other Sierra has for MAP sensor and take it from there. That's probably the cause.
Old Dec 10, 2007 | 09:11 PM
RS Essie's Avatar
RS Essie
ok thx
3dr cossie
11
Dec 21, 2015 03:38 PM
andyrs1600i
Aug 30, 2015 07:21 PM
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
