turbo rebuilding
Old Dec 2, 2007 | 02:22 PM
mechanick's Avatar
mechanick
Default turbo rebuilding
hi there, has anyone had a go at rebuilding their turbo, have a stage 2 turbo on my escort and noticed there is rather a lot of side to side movement in the shaft, the turbo doesnt smoke, how hard is it to change the bearings?, have seen full turbo kits on ebay quite cheap and was wondering!
Old Dec 2, 2007 | 02:43 PM
RickyLee53's Avatar
RickyLee53
Default Re: turbo rebuilding
Not very hard to do really, but it won't be balanced when you put it all back together. You can mark it all up so its the same balance as it was when you took it to pieces though.
Some turbo's have special shaped nut's, not sure if the RST turbo is 1 of them.
Old Dec 2, 2007 | 03:16 PM
mechanick's Avatar
mechanick
would mark it up anyway, just to make sure, anyone know where i could find a guide to do it?
Old Jan 22, 2008 | 04:39 AM
testastretta999's Avatar
testastretta999
Default Turbo
I think it is relatively easy to swap parts, however spinning at 10,000's rpm I would want it balanced.
Old Jan 22, 2008 | 07:24 AM
LHD220Turbo's Avatar
LHD220Turbo
you'll need a balancing machine to do it properly, best of getting it done professioanly and not cut any corners imo
Old Jan 22, 2008 | 10:14 AM
stevecossy's Avatar
stevecossy
As above get it done properly or it could end in tears, we all like to think we can fix owt but its not that simple.
Remember buy cheap buy twice.
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
rsturbo27
Sep 1, 2015 09:54 PM
