cossie not ruunning right help!!!!!
Old Nov 29, 2007 | 06:59 PM
k10cos's Avatar
k10cos
Default cossie not ruunning right help!!!!!
hi guys
could anyone help me
my cossie is not idling right also popping sounded like the on of the injectors not working turns out there are fine but changing ifound that the fourth injector leed is not working, ie when you take the injector leeds of on 1 2 & 3 the idle drop and on fourth it does nothing?
also checked the power to the injectors and thats fine and re wired it
i have changed
coil
leads
spark plugs
distribution cap
rotar arm
injector
could it the 3 bar map senor or ecu?
Old Nov 30, 2007 | 10:19 AM
stevecossy's Avatar
stevecossy
IT could be ya ecu and also could be the wiring to the inj. Also check ya phase sensor but would of thought it do it on all inj if it was phase. If ya can get hold of the cossy tech manuel then it gives ways of testing inj s and wires but i cannot remember what it says. good luck
Old Nov 30, 2007 | 11:09 AM
k10cos's Avatar
k10cos
Default thanks
anyone else
i will try the ecu!!!
need to find some thats got one local to me
Old Nov 30, 2007 | 05:54 PM
mechanic28's Avatar
mechanic28
do a compression test to make sure its not a mechanical fault
Old Dec 1, 2007 | 10:13 AM
Rolls's Avatar
Rolls
when mine did this I had a leaky inlet gasket... - worth checking with carb cleaner
Old Dec 19, 2007 | 09:51 PM
mappindude's Avatar
mappindude
Yeah i ,d go with rolls its worth a try.
But to improve your chances weaken the idle mixture first, so it just about idles .so if the easy start or carb cleaner gets into the inlet manifold it will be more noticeable.
Old Dec 20, 2007 | 08:25 AM
It could well be a sticky injector, they do this if stood long enough as the fuel varnish clogs things up.
Try swapping the injector over to see if it moves the problem.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
