bilstein damper
Old Nov 22, 2007 | 06:13 PM
garrett-killer's Avatar
garrett-killer
Default bilstein damper
hi!
i need a good suspension for my
escort cosworth.
i found this:
http://www.europerformance.co.uk/pag...tml?id=3657900
i used bilstein on my fiesta rst before and was happy with it.
someone use this suspension on his cossi?
are the damper "thicker" than the stock dampers?
my problem are the 18" rondell with 225/40 yokohama.
i´ve got ~2cm between tyre and spring cup.
and i dont want spacers!
someone know if i can use this combination?
best regards chris
Old Nov 23, 2007 | 03:31 PM
Aaroncast's Avatar
Aaroncast
2cm= 20 mm------------no problem
Old Nov 23, 2007 | 03:39 PM
garrett-killer
thank you,
whats your opinion about
bilstein-koni-spax shocks?
is it important to have adjust able shocks?
has someone made a comparison?
best regards chris
Old Nov 23, 2007 | 04:26 PM
jon@work's Avatar
jon@work
Chris - if you want a decent suspension set-up, have a chat with Mike Rainbird, or send him a PM.
IainRS1700T
Sep 25, 2015 06:44 AM
Matt Baxter
Sep 16, 2015 08:30 PM
truffleshuffle
Sep 10, 2015 09:35 PM
A.t.p
Aug 15, 2015 11:37 AM
sierra cossie
Aug 7, 2015 12:17 AM
