charging problem
Old Nov 21, 2007 | 02:53 PM
mechanick's Avatar
mechanick
Default charging problem
right got a escort rst, which has a charging problem, its got a new battery, new starter motor has had 4 new 70 amp alternators on it, all warranty claims, replaced all engine to body/battery to body earths, checked all resistances through main battery leads found nothing wrong, still acts like the battery is flat, when its running and your driving, turning heater on, or electric windows, the battery lamp comes on dimly has anyone got any ideas?
Old Nov 21, 2007 | 05:07 PM
djmillsy's Avatar
djmillsy
Fife Radge
alternator wires check them especially the thin blue wire
Old Nov 21, 2007 | 05:23 PM
mechanick's Avatar
mechanick
the blue runs to the dash board rite?
Old Nov 21, 2007 | 06:03 PM
djmillsy's Avatar
djmillsy
Fife Radge
it hink so mate cant mind as mine is stripped it makes the bat light come on faint and gave me the symptons you descibed
Old Nov 22, 2007 | 04:25 PM
3iturbo's Avatar
3iturbo
i had the same prob i changed the blue wire from the black box in dash and now works ok....if no look change the wires from the starter to the bat....hope that helps
Old Nov 24, 2007 | 04:16 PM
mechanick's Avatar
mechanick
cheers will give that a try, its just doing my head in even been round the car checking all the earths inside its better but still not right , dont ya just love rs's lol
Old Nov 25, 2007 | 09:11 AM
Wardy257's Avatar
Wardy257
Default Re: charging problem
There is no point in checking the resistance of the battery leads they will never fail. You need to volt drop!!!!!
Old Nov 25, 2007 | 09:23 AM
NUTS RuS's Avatar
NUTS RuS
Does the red light only come on under load ?
Old Nov 25, 2007 | 10:02 AM
JesseT's Avatar
JesseT
Car running and device on (lights, rear screen heater, etc...) Measure the voltage from the battery terminals. Then measure the voltage between the alternator B+ pin and the case. Is there a difference more than half a volt?
Old Nov 25, 2007 | 07:14 PM
mechanick's Avatar
mechanick
the light is really faint under normal running, comes on brighter when under any load such as wipers, windows, even brake lights,
gonna check all this tomorrow at work, didn't bring any tools home this weekend,
cant be my week went out last night now the engine knocks think some new big ends might be in order too lol
Old Nov 27, 2007 | 07:55 PM
daveselwood's Avatar
daveselwood
Default alt
i had the same problem and the wire the runs from alternator to starter had corroded, if not a wire it might be the brush pack
Old Nov 28, 2007 | 05:08 PM
rst230bhp's Avatar
rst230bhp
i have exactly the same problem driving me mad, what i have been advised to check is behind the front right speaker cover there is a screw with a load of brown wires going to it, this normally corrodes, also check your back lights aint flashing stupidly as as when i indicate the brake light flashes aswell, i believe theres water getting into the light. ive ordered new seals. hope u get it sorted
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
