mk 6 escort 1.8si
Old Nov 19, 2007 | 01:42 PM
mart.rs's Avatar
mart.rs
Default mk 6 escort 1.8si
got a on going problem with my 1.8 zetec si,its got a major air leak somewhere ive changed the idle valve controller so i know its not that,and ive checked the maf sensor too thats fine aswell. Whats happening is it justs holds the revs at 2000rpm in the traffic and if you just blip the throttle at standstill too then the revs fluctuate and if your driving along at 30mph (for example) the car just jerks in gear occaisionally,im stumped!
Old Nov 19, 2007 | 01:44 PM
lukemakepeace's Avatar
lukemakepeace
you might need to reset the ECU. i cant remember ho to do it tho but that might me it, or just adjust the idle control valve.
Old Nov 19, 2007 | 07:16 PM
Wardy257's Avatar
Wardy257
How do you know it is an air leak? HAve you done the WD40 test? Try disconecting the MAF and see if it gets better.
Old Nov 20, 2007 | 10:42 AM
mart.rs's Avatar
mart.rs
cheers for the help guys ill give it a go
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
