2wd cossie wiring loom help
Old Oct 8, 2004 | 10:32 PM
blaazer2's Avatar
blaazer2
Default 2wd cossie wiring loom help
all i need to know is what the colour codes are for ....temp gauge.....perm live.......ignlive........rev counter.......fuel pump , on a 2wd cossie engine loom so i can get it to run ............i have wired up the engine and plugged in the ecu but i dont know what you do with the other bit of wire
Old Oct 9, 2004 | 06:33 PM
rocar's Avatar
rocar
Temp Brown/White
Live Blue /Red
Igntion Black
Rev Counter Green
Fuel pump Black/Red
Roger
Old Oct 9, 2004 | 08:12 PM
blaazer2's Avatar
blaazer2
thanks mate ,i just spent two hours with a pin data book and a multimeter ,i came to the same conclusion before i read your message any way the wires you have just described on that plug has a sixth wire [brown/ red] which when earthed operates a 3rd relay on the cossie engine loom ,the other two switched wires on the 3rd relay run back to the ecu Q............do you know what this does ... .......................................thanks really appreciate your help
Old Oct 11, 2004 | 01:20 PM
jon@work's Avatar
jon@work
the third relay (purple) is for the engine management warning light on the dash.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
s1turboman
Aug 29, 2015 04:27 PM
salsheikh
Alloy wheels and ICE for sale
Aug 20, 2015 12:33 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
jdsjojo
Aug 1, 2015 08:50 PM
