2.0 zetec into a mk3
Old Nov 12, 2007 | 08:12 PM
dovboy's Avatar
dovboy
Default 2.0 zetec into a mk3
as above,what sort of problems will i run into or is it quite strait forward?
Old Nov 12, 2007 | 08:28 PM
mark_24v_wiring's Avatar
mark_24v_wiring
Simple as mate really just a couple of things you need to know,
Drivers engine mount needs to have the 3rd hole made so it bolts to the block you will understand when you try it water pump needs to be from an rs1800 also alternator bracket you need a 1.8 flywheel 220mm clutch (rs turbo) bung it all in on the cvh box (1 bolt wont go in as there is not a hole on the block) cvh starter plumbing it up should be easy 2
Old Nov 12, 2007 | 10:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Done it years ago didn't you Brother
Was a good little car that.
Steve.
Old Nov 13, 2007 | 05:12 AM
mark_24v_wiring
Yeh dont you know it and if i carry on feeling the way i do at the moment you and i will be making another one
Old Nov 13, 2007 | 04:33 PM
dovboy's Avatar
dovboy
cheers guys
Prickly_buzz
Dec 7, 2017 09:52 PM
Fiddy
21
Sep 29, 2015 06:10 PM
The Enigma
Sep 29, 2015 10:31 AM
SMILER258
Sep 28, 2015 09:04 AM
BENJAMIN_21
Ford Fiesta
Sep 17, 2015 08:58 AM
