innovate xd16
Old Nov 7, 2007 | 04:42 PM
bassboy's Avatar
bassboy
Default innovate xd16
hi does anyone have any experience of this unit? also is it a standalone unit...i.e can it be used as a wideband AFR gauge (by connecting to the lamba sensor) without spending a small fortune on the data logging innovate gear?
cheers for any help
bassboy
Old Nov 7, 2007 | 04:51 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
It ships with the "sensor cable" setup normally.
So when it arrives, you can just install it.
Old Nov 7, 2007 | 05:27 PM
Daxcossie's Avatar
Daxcossie
It will only work as an AFR gauge and the alarm functions will not operate unless you have the logging equipment etc.
Old Nov 9, 2007 | 07:27 AM
Yura's Avatar
Yura
Did anyone use LC-1 and lamda sensor as factory lamda and a/f gauge simultaneously? LC-1 have linear output which generete the signal 0-1V which can swap the factory lamda signal, but I don't know how it will be work in action...
Old Nov 9, 2007 | 08:38 AM
Daxcossie's Avatar
Daxcossie
Was the factory sensor wideband ?
Old Nov 9, 2007 | 09:12 AM
Yura's Avatar
Yura
no, from LC-1 manual:
"the analog output connector of the LC-1 can simulate the operation of narrow band sensor while the wide-band oxygen sensor is installed in place of the OEM narrow-band sensor. Factory equipped Analog output 1 of the LC-1 is programmed to simulate a narrow band sensor...."
Old Nov 9, 2007 | 09:47 AM
grcossie's Avatar
grcossie
I use it like this, it is two analog output, i use nr one yellow cable to ecu
Old Nov 9, 2007 | 11:42 AM
Yura's Avatar
Yura
Do you use it with standart settings or make some corrections by LM Programmer for correct working?
Thanks!
Old Nov 14, 2007 | 09:58 AM
grcossie's Avatar
grcossie
I use it like standar, output 1 is correct set like this
Old Nov 28, 2007 | 08:42 AM
Yura's Avatar
Yura
grcossie
There are 3wires to std lamda. First - signaling wire to pin2 ECU, Second - ground, Third - +12V. Did you connect ground and +12V to somewhere ?
Christian and Beccy
Apr 6, 2010 10:31 AM
Christian and Beccy
Apr 29, 2008 08:32 AM
KSA-Cossie
15
Dec 20, 2007 09:42 AM
Turbocabbie
Computers, Consoles and I.T.
Jan 30, 2007 11:53 AM
