escort rs turbo firing order
as above i know it is 1 3 4 2 but has any1 got a pic of the dizzy and which 1 is number 1 and if its clockwise or anti clockwise
thanks steve
thanks steve
if your timimng is correct then remove the dizzy and crank the engine to see the rotation, then as you look at the engine the left first piston is number 1 when this is at tdc your rota will be pointin at number one, then go from ther 1342, pretty sure its clocwise
muz
16-08-2015 12:57 PM
