My car is possessed!?!?!?
Old Oct 22, 2007 | 06:16 PM
james.dylan83's Avatar
james.dylan83
Default My car is possessed!?!?!?
Chaps and Chappettes,
Really hope someone can help me. The idle on my 1800 focus rises as i slow down, rolling along in traffic with foot on clutch at 10 mph revs show 2500!! I've repaired collapsed pipes, cleaned the maf, iscv and throttle body and it's now performing perfectly apart from this. Anyone else had/have this problem, any solutions would be much appreciated. I'm starting to get really hacked off with the car and really need your help.
Thanks,
James
Old Oct 23, 2007 | 03:53 PM
lukemakepeace's Avatar
lukemakepeace
sounds odd but is there any chance you could have mis adjusted the idle control valve?
Old Oct 23, 2007 | 04:08 PM
james.dylan83
not adjustable, just a lump of metal with complicated magic inside everything i've tried has made it run cleaner, rev better but now this has started to really bug me.
Really could use with a definate suggestion from someone, vss maybe?
Old Oct 25, 2007 | 04:16 PM
charlieboy's Avatar
charlieboy
idle control valve is the problem im in the middle of sorting mine out now!
Old Oct 25, 2007 | 04:53 PM
james.dylan83
cheers for your help folks, after i cleaned the iscv i reset the ecu and it was still doing it. 127 miles later it's all sorted, runs smooth as silk and even pulls harder. just takes a while to settle
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
