compression in s1
Old Oct 3, 2004 | 04:24 PM
pauls.ego's Avatar
pauls.ego
Default compression in s1
tested compression in the s1 sat got same reading in all pots of 140 ..want to know what is the correct compression????i know if there all the same or within 10% of each other there ok ...car is standard apart from kn panel magnex running 8 psi of boost..140 seems a bit low compared to other posts on pf site .thanks to all in advance of replies
Old Oct 3, 2004 | 09:23 PM
Grahamxx's Avatar
Grahamxx
When I owned a Series 1 the compression test's that I did came out at 150psi each. As long as they're all within 10% you should be ok
Old Oct 4, 2004 | 10:51 AM
pauls.ego's Avatar
pauls.ego
cheers m8
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
