s2 popping and banging on boost
Old Oct 5, 2003 | 10:07 AM
RScrew69's Avatar
RScrew69
Default s2 popping and banging on boost
hi peeps, my s2 has recently just started popping and banging when it comes on to boost recently, the car also kinda jerks at the same time.
Any ideas as what could be the problem with her? shes stage 1 tuned i.e chip, bout 14psi, induction kit, s/s pipe, samcos etc.
someone said plug gaps, what should they be? as i always use ngk 705's i thought they were already pre-gapped from factory?
hope u can help peeps
cheers
Old Nov 23, 2003 | 02:44 AM
Default hi mate
check your metering unit is clean push down the flap to see
Old Nov 23, 2003 | 09:28 PM
EIL132's Avatar
EIL132
The plugs are wrong, should be BCR8ES's.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
