main prop removal
Old Sep 15, 2007 | 08:37 PM
redrsmk5's Avatar
redrsmk5
Default main prop removal
Hello
Ok im trying to remove all items from my underside to do my resto. Have undone the main centre bearing, have undone the 3 nuts and bolts on the spider at the rear of front transmission, how do i stop the prop and diff from turning so that i can undo the 15mm bolts that hold the prop onto the front of the rear diff? car is on stands with all rear brakes removed so cant use handbrake
Any help welcome a lot
MArt
Old Sep 15, 2007 | 10:31 PM
jon@work's Avatar
jon@work
stick a pry bar or big screwdriver through the UJ spider and trap it against either the car or garage floor
Old Sep 16, 2007 | 06:44 AM
Yep that is what I would do as well.
Old Sep 17, 2007 | 05:50 PM
redrsmk5's Avatar
redrsmk5
Thanks guys
Mark_
40
Oct 2, 2015 04:40 PM
rsguy
44
Sep 29, 2015 03:29 PM
The Enigma
Sep 29, 2015 10:31 AM
