OverHeat problem!
Old Sep 2, 2007 | 08:54 PM
mrandmrsharrison's Avatar
mrandmrsharrison
getting comfy...
Default OverHeat problem!
Car running in red..what could be the cause? its doing it even without the stat out!
Any ideas would be welcomed cheers
Old Sep 2, 2007 | 09:37 PM
antony215's Avatar
antony215
Escort Rs Turbo
Head gasket
Old Sep 2, 2007 | 09:58 PM
mrandmrsharrison
getting comfy...
had one still does it!
Old Sep 2, 2007 | 10:51 PM
Grandad racer's Avatar
Grandad racer
when you switch on the ignition, make sure the temp gauge is at the bottom, mine went halfway up when switched on. with the ignition turned on pull off the needle and reset it at cold.worked for me!!
Old Sep 2, 2007 | 11:40 PM
antony215's Avatar
antony215
Escort Rs Turbo
Is the car actually overheating???
Old Sep 3, 2007 | 05:37 AM
My thoughts exactly, is it in fact over heating or do you just have a dodgy gauge.
If this hot in reality the heater would be scalding hot, is it ?
How long does it run like this, is the water boiling ?
Old Sep 3, 2007 | 09:03 PM
MarkN's Avatar
MarkN
It could just be the pressure cap - have you tried replacing this?
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
