HELP VERY HOT ECU !!!
Old Sep 30, 2004 | 12:05 PM
tony gray's Avatar
tony gray
Default HELP VERY HOT ECU !!!
START MY 2WD SAFF IT STARTS NO PROBLEM BUT THE ECU GETS RED HOT AFTER ONLY RUNNING FOR 2 MIN.CHECKED PLENIUM EARTHS ALL OK -ANY IDEAS AS IM RUNNING OUT OF LEVEL 6 ECUS!
Old Sep 30, 2004 | 05:09 PM
Dave Henshall's Avatar
Dave Henshall
could be a short in one of the circuits that the ecu drivers drive, like injectors, amal valve or idle valve. it will get aired, but should not get HOT. disconnect it and check all the loom for cracks, shorts or corrosion.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
DixieTheKid
Sep 14, 2015 09:04 PM
