Viewing a saff cossie....
Old Jan 17, 2004 | 04:13 PM
Dave McB's Avatar
Dave McB
Default Viewing a saff cossie....
Just been to see a 2wd Saff, and couldn't find the mag I had with the buying guide in it.
Had a good lookie over, and im goin back to see it on Monday night.
Can anyone help me with what I should have looked for and what I should definitely be lookin for?
Old Jan 17, 2004 | 04:20 PM
dave cos4x4's Avatar
dave cos4x4
Be better in the daylight, or somewhere where there is good lighting.
Do a search on here and see if there is a guide.
Only know that they do go on the chassis rail where the back wishbone bolts on to.
Dave.
Old Jan 17, 2004 | 08:49 PM
Not too sure about anythinb thourough you should check for on a 2wd but here's a generall guide.
Look around all bodykit fixings for rust. Rear lower arms, the arms themselves and mounting locations. Front and rear bumper mounts. Front and rear aches, usually rusts on the lips.
Check it ain't bent, all gaps are parallel, the bonnet is sitting true. Open up the boot and pull up the carpets, check that the panels are not creased or wrinkled, a sign of a rear end shunt. Also check that the roof linning isn't sagging as this will be an indication of the car having rolled.
Check that none of the wheels are buckled or that there isn't any positive camber (think its positive camber) when the top of the wheel sticks out and the bottom sticks in, this is usually due to power sliding into kerbs, can be very expensive to fix. Lowered sierra's usually have negative camber, top sticks in, bottom sticks out, not to worry about unless its extreme.
Engine wise, you want to see the car cold. On start up listen out for excessive tapping, you'll get some on a high miller, common to pinto's. White smoke (not condensate), blue smoke or black smoke. Overrun when you switch the engine off, signs of turbo death.
Check the rear drive and shafts. The axles shouldn't be loose, there'll be play back and forth but not in a radial direction. Look for leaky oil around the drive and gearbox.
Can't think of much else off the top of my head. Just do the general checks, it is a sierra after all. Head gaskets, loose gear change, clutch wear and so forth.
Hope that helps.
Old Jan 18, 2004 | 12:18 AM
Dave McB's Avatar
Dave McB
From what i seen today the one i looked at looked straight, well looked after and smart. Didny check chassis legs tho
Im takin a mechanic to c it on Monday, and (fingers crossed) il b a cossie owner(finally) by next weekend
Old Jan 18, 2004 | 10:56 AM
dave cos4x4
Hope everything is o.k for you!!
Dave.
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
stevecfrst1
Sep 30, 2015 05:18 AM
cossie330
Sep 27, 2015 04:13 PM
