What flywheel??
Old Aug 19, 2007 | 08:08 PM
ShandzS1's Avatar
ShandzS1
Default What flywheel??
I am putting a standard 1.8 zetec 130bhp, in to my mk3 escort. I`ll be using the crank sensor, but dont know what flywheel, clutch set-up to use. Was thinking maybe cvh efi flywheel and clutch? Oh and i`m using mk3 xr3 g-box...
CheeRS Neil
Old Aug 20, 2007 | 05:29 AM
ShandzS1's Avatar
ShandzS1
Someone must of done this conversion before.........
Old Aug 20, 2007 | 06:17 AM
Wardy257's Avatar
Wardy257
Just keep the ZETEC flywheel and clutch.
Old Aug 20, 2007 | 05:30 PM
ShandzS1's Avatar
ShandzS1
its got the wrong splines, it had an mtx75 box on it b4, clutch is way bigger
Old Aug 20, 2007 | 10:50 PM
XR_Cos's Avatar
XR_Cos
both gearboxes have 1" 23 spline input shafts, so the original zetec flywheel and clutch will fit the xr gearbox.
Old Aug 21, 2007 | 05:34 PM
ShandzS1's Avatar
ShandzS1
yeah found out that the 105bhp flywheel and clutch or cvh clutch will work. what engine mount do u use for the zetec, ive moddded the bracket on the block, but my rubber mount fouls the oil pump
Prickly_buzz
Dec 7, 2017 09:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
