presure in the cooling system?
Old Aug 14, 2007 | 10:58 AM
Windle's Avatar
Windle
Default presure in the cooling system?
should the pipes feel like there is presure in them? and how much?
the pipes on mine feel quite hard, but the cooling seams fine. Rarely goes over half way on the gauge?
normal?
Old Aug 14, 2007 | 11:29 AM
dave green's Avatar
dave green
Most cooling systems run when hot with about 15 psi, if any more then you may have a head gasket problem
Dave
Old Aug 14, 2007 | 01:42 PM
If not using water etc then normal, 15psi might not seem a lot, and most don't have anywhere near like this amount anyway but when it is water pressure inside a pipe/vessel it is massive as water is denser than air, they will be firm when hot.
Old Aug 14, 2007 | 08:44 PM
Windle's Avatar
Windle
doubt gaskets at fault its litrally 1 week old with a fresh new head
everything looks fine just never noticed pipes b4
Old Aug 15, 2007 | 07:56 AM
You worry too much, you should be a cossie owner as we worry too much too!!
Old Aug 15, 2007 | 12:24 PM
Windle's Avatar
Windle
i have an rs turbo i have to worry, look at the gauges more than the road when i drive! damn car but i love it
Old Aug 15, 2007 | 04:15 PM
denbo's Avatar
denbo
Windle am the same as you fella looking at all the gauges more than the road
Old Aug 15, 2007 | 05:09 PM
I look at any TOTTY, failed my first driving test due to looking at girl, and ramming the car in front at the lights!!
Old Aug 15, 2007 | 05:47 PM
Windle's Avatar
Windle
rofl classic, at least wait till you had passed your test
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
coscor86
Sep 20, 2015 01:21 PM
