frst abs removal, help!
Old Sep 28, 2004 | 09:40 PM
RScrew69's Avatar
RScrew69
Default frst abs removal, help!
hi peeps,
ok abs was removed in my frst today, basiclly used non abs master cylinder with the green brake pipes connected to the 2 twin barrel things which bolt on to the inner wing, and the 2 green brake pipes that follow up from under neath the car.
swapped all the units over and have tried getting brakes working, but the pedal keeps going to the floor and when u press the brake pedal when u pump it the revs of the car begin to rise up.
I checked the brake pipes and the green metal pipe on the master cylinder that runs off to the drivers wheel has fluid bursting out of it when u loosen the brake line bolt off, however the pipe that runs of to the passenger front wheel has nothing coming out of it when u pump the brake and remove the green brake pipe thats attached on the master cylinder.
my conclusion so far is all the brake lines are fine, but the one that goes to the passenger front wheel is blocked up, if i remove the master cylinder, how can i clean o what can i use to clean it out with and will be safe and strong enough to mix and clear the blockage up. Baring in mind the substance must mix with brake fluid.
cheers in advance guys
Old Oct 15, 2004 | 09:36 PM
blaazer2's Avatar
blaazer2
this sounds more like the master cylinder seals have gone
Old Oct 15, 2004 | 09:40 PM
jayRS's Avatar
jayRS
did you bleed it right?
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
