Cossy Dizzyless. Whats involved??
Old Aug 6, 2007 | 07:38 PM
jacko996's Avatar
jacko996
Default Cossy Dizzyless. Whats involved??
thinking about going Dizzyless, but not sure whats involved.
Good or bad points??
Any help appreciated
dave
Old Aug 15, 2007 | 11:00 AM
James's Avatar
James
try a search or check out the MSD [Stu] website for more details and prices.
Old Aug 15, 2007 | 01:20 PM
mikelomax's Avatar
mikelomax
MOUSE
stu at msd has done mine and its great. fires straight away and never misses a beat.
whats involved.
1.coilpack and loom
2.twin ignition amps
3.coilpack leads
4.coilpack driver in ecu
5.mod on back of rev counter.
stu supplies all the parts as a diy job. this is what i did but just got stu to put the driver into the ecu. the mod on the rev counter is really easy.
he does the whole job with full instructions as a diy kit for Ł400
http://cgi.ebay.co.uk/Cosworth-Waste...QQcmdZViewItem
hope this helps
mike
Old Oct 31, 2007 | 04:47 PM
jacko996's Avatar
jacko996
Thanks chaps
I have seen ones with a cam trigger attached to the cam cover, whats that all about??
Old Nov 23, 2007 | 04:48 PM
- Sim -'s Avatar
- Sim -
this is - as far as I can explain it
the coipack kit uses the existing distributor to trigger the coilpack, to go dizzyless you must fit a cam trigger.
For that reason the cam has to be machined and the camcover also to fit the cam trigger sensor.
Ryan expained this to me, much better
but I hope you understand it.
Old Nov 23, 2007 | 11:19 PM
Moonstone Mart's Avatar
Moonstone Mart
You can go coilpack but you still need the dizzy/phase sensor for the trigger.
The sensor on the cam cover uses a trigger fitted to the inlet cam. If you want the dizzy removing you will need to fit something to run the oil pump (normally done by the dizzy).
Better description/pics here - https://passionford.com/forum/viewtopic.php?t=194126
Mart.
Old Nov 25, 2007 | 09:45 PM
ECU Monitor Enthusiast
You do NOT need a cam trigger to run wasted spark.
You ONLY need that if you wish to remove the dizzy completely.
Old Nov 25, 2007 | 09:56 PM
Moonstone Mart
As i said....sort of
Mart.
Old Nov 25, 2007 | 09:58 PM
Mart.
Yes mate sorry I saw that after I posted
Old Nov 25, 2007 | 10:02 PM
Moonstone Mart
Lol no worries, your answer was easier to understand.
Mart.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
