HELP NEEDED!!!! WARNING LIGHTS ON 98' Escort GTI
Old Jul 21, 2007 | 07:41 PM
BAZZA BOY's Avatar
BAZZA BOY
Default HELP NEEDED!!!! WARNING LIGHTS ON 98' Escort GTI
I was hoping that someone could help me here.
what it is, is that the traction control light and the abs light stay on while driving. this only started this afternoon, and i am bit confused what this could be.
as stated my car is a 1998 escort gti 3dr, no mods etc.
if anyone could help then that woud be great.
cheers in advanced
Baz
Old Jul 21, 2007 | 07:58 PM
flatoutcos's Avatar
flatoutcos
the traction control and abs use the same sensors,
it will be one of the wheel sensors that is faulty,often the wires corrode away,
the hard part is finding which one it is,unless you have a scanner to plug into it!!
Old Jul 21, 2007 | 08:42 PM
BAZZA BOY's Avatar
BAZZA BOY
Cheers for that mate.
Where abouts are the sensors located?
Old Jul 21, 2007 | 11:26 PM
bluescortcossie's Avatar
bluescortcossie
my old Si (same engine) used to do this , well abs anyway as no TC , it always did it when there was a lot of water about then stopped when it dried out , good starting point would be to dry all the sensor connectors and see if that fixes it , if so use some damp start stuff to seal them
also my airbag light used to go crazy if i went through a big puddle , typical ford electrics !
Old Jul 22, 2007 | 09:52 AM
D.K.'s Avatar
D.K.
common on these cars, mine done it and then would go off for a few days and come back on again, as said above they are known to corrode, mine was rubbing tho.
Just stick a bit of black eletrical tape over the warning light on the dash and you wont see it
Old Jul 22, 2007 | 07:16 PM
BAZZA BOY's Avatar
BAZZA BOY
THANKS for all your hlp peps, it seems to be ok today, so i think it could e due to the heavy rain yesterday(well I hope o pmsl)
cheers again
baz
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
