P8 / L8 chip
Old Jul 21, 2007 | 08:20 AM
JanDK's Avatar
JanDK
Default P8 / L8 chip
Stupid Q I know, just need to make sure.. there are NO chance that a P8 chip will go in to a L8 ?? I might have ECU trouble.. needs testing, maybe replacent ECU
Old Jul 21, 2007 | 11:56 AM
2001ode's Avatar
2001ode
Hi,
You have no chance.
Totaly different ECU.
Regards
Claude
Old Jul 21, 2007 | 12:53 PM
I don't think his chances are as high as no chance, even less than no chance!!
Old Jul 22, 2007 | 09:12 AM
JanDK's Avatar
JanDK
thougth so.. just needed to be 101% sure.
Old Jul 22, 2007 | 10:27 PM
Stu @ M Developments's Avatar
PassionFords Creator
Go "INTO"
Yes it will fit into a L8 or P8 chip socket no problem, identical configuration. It just wont run pal.
Also, if your messing with chips, ensure you put the chip in the right way around.
Old Jul 23, 2007 | 06:45 AM
L8 is weber marelli, P8 is ford eec,
P8 is way more powerful than L8 as well
*Edited by Stu@msd to add*
Sorry pal, i edited your text by mistake instead of pressing quote i pressed edit and cant get it back now. really sorry mate. Stu. *
Old Jul 23, 2007 | 07:07 AM
JanDK's Avatar
JanDK
thank you Fordfriends .. just needed to be sure as I am trying to exclude some faults, thats why I in a micro sec. thought, maybe the chip could fit one way around (and run ofcause). But now I will just borrow another ecu.
Old Jul 23, 2007 | 07:09 AM
P8 is ford eec,
Its not, its weber marelli mate.
P8 is way more powerful than L8 as well.
Its not really... its just a little faster with some more memory space.
Theres a lot of untrue speculation out there about P8 sadly.
Old Jul 23, 2007 | 10:17 AM
I must have misread GGR site !!
My eyessight is going as I am getting old.
When are you going to do closed loop on L6 or is it never going to happen ? ie is it just not at all suitable ?
Old Jul 23, 2007 | 10:38 AM
Its not really suitable as you would need teh additional memory expansion board and the motherboard populating with missing components too.
Old Jul 23, 2007 | 11:21 AM
That's a shame as it would have brought it into the present day and out of the dark ages!!.
Thanks for the reply.
Old Jul 23, 2007 | 12:05 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Originally Posted by Stu @ M Developments
Go "INTO"
Point the chip so the notched end of the chip is the same end as the notch in the socket
tankybaby66
Feb 6, 2016 02:24 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
RSmark84
Sep 13, 2015 01:29 PM
