Cosworth Oilpump driveshaft
Old 17-07-2007 | 06:03 PM
MARCOSWORTH's Avatar
MARCOSWORTH
Default Cosworth Oilpump driveshaft
Can i reuse the ''ring'' around the driveshaft from the oilpump,got a new one from Ford without the ''ring''
Thanks.
Old 17-07-2007 | 07:03 PM
Yes, if not a tight fit flatten it with a hammer then it gets really tight.
Old 17-07-2007 | 07:15 PM
jon@work's Avatar
jon@work
or just don't bother fitting the ring at all
Old 17-07-2007 | 07:44 PM
As jon says it is not actually needed anyway.
Old 18-07-2007 | 12:15 AM
MARCOSWORTH
Thanks guys.
In the manual they say ''Insert the oil pump shaft with the short side towards the oilpump"
Have to check the old one
Old 18-07-2007 | 12:16 AM
Jamie200's Avatar
Jamie200
Think it's ther to stop it being pulled out if the distributor is removed. I have seen them without, but I'd re-fit it.
Old 18-07-2007 | 01:57 PM
velocity's Avatar
velocity
cant remember exactly, but when rebulding mine i can recall the washer being a set distance along the shaft and depending which way you put the shaft in it will determine how much it engages in either the dizzy drive or the oil pimp drive.although not sure if it actually does make any real difference
Ford Focus RS Parts for Sale.
09-03-2016 02:03 PM
05-11-2015 09:12 PM
Adam Graham
06-09-2015 07:04 AM
rsturbo27
05-09-2015 06:08 PM
wheelwizardrefurbs
05-09-2015 11:52 AM
