Escos Steering Creak
Old Jul 17, 2007 | 08:56 AM
bpspa's Avatar
bpspa
Default Escos Steering Creak
Hi,
When I turn the steering wheel on my escos at very very low speed or stationary, I get a creaking noise coming from the front.
Do I remember rightly this noise is caused by the bushes on the top of the strut and replacing them will solve the problem?
Also if it does solve the problem any particular ones I should get or are the normal ones from Ford ok?
Ben
Old Jul 17, 2007 | 11:40 AM
Will not be the bushes unless loose and worn as they effectively clamp a "cup" either side, under the lower cup piece is a bearing, which the strut turns on, or should anyway may be a bit sticky, I used to get a twang as the srping platform released all of a sudden when mine used to stick, so greased up bearings all ok now.
Old Jul 17, 2007 | 04:52 PM
THE RADMAN's Avatar
THE RADMAN
sounds like the top cup has broken,very common fault,if you remove the nut in engine bay,take off the strut top cover and look in the hole you will be able to see if the cup below is broken or not
Old Jul 18, 2007 | 06:37 AM
bpspa's Avatar
bpspa
thanks tabetha and Radman, will take a look at the weekend
Old Jul 19, 2007 | 06:00 AM
bluescortcossie's Avatar
bluescortcossie
just a quick note , mine did the same and the cup was broken
both cups and bearings were available from ford when mine went (3 years ago) and if i remember right they were quite cheap
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Mickeystewart
Sep 9, 2015 04:04 PM
