mk4 escort van+cossy wheels?
Old Jul 16, 2007 | 10:58 PM
////ANTHONY's Avatar
////ANTHONY
Default mk4 escort van+cossy wheels?
just got myself a mk4 van with an rst engine already fitted, it need a lot of tidying and the 1 pc rear door fitting, its got erst wheels on but id like to know if the escort cossy wheels with 205 45s will fit without modifing anything? anyone know where i can get lower leaf springs from for it?
Old Jul 16, 2007 | 11:01 PM
djmillsy's Avatar
djmillsy
Fife Radge
wheels should e fine mate maybe need a spacer im not sure dont now about springs though just fill the back with bags of sand
Old Jul 16, 2007 | 11:15 PM
////ANTHONY
thanks, i have the wheels already on my mk5 van ith spacers, but i dont have the locking nut key for the wheels on the mk4 anyone know how i han get them off
Old Jul 17, 2007 | 06:37 AM
bluescortcossie's Avatar
bluescortcossie
the wheels should fit but be careful of rubbing
to drop the back end you can flip the leaf springs over or use lowering blocks ( or both ! )
to get the locking nut off you need a socket which has a left hand thread on the inside , sometimes see them on fleabay
Old Jul 17, 2007 | 06:40 AM
bluescortcossie
locking nut socket
http://www.uktools.com/product_info....aa00f5b2ff63a4
Old Jul 17, 2007 | 10:35 AM
////ANTHONY
thanks blue, ill have to order one of them sockets,
can you only use the lowering blocks once the axle has been put on top of the leaf spring? i cant think where else the lowering block would go apart from at the front of the spring by the petrol tank
Old Jul 17, 2007 | 02:02 PM
bluescortcossie
they fit between the spring and the rear beam (axle) , if you look where the beam bolts on there will be 2 "U" clamps either side , take these off , lift up the beam , put block between beam and spring , put on a longer "U" clamp and job done
Old Jul 17, 2007 | 09:57 PM
////ANTHONY
thanks, one thing thats worried me about putting the axle on top is will the U clamps be strong? because ill have alot of audio in the back of the van, maybe 300kg, even 300kg wont lower the van much because i have all this audio in my mk5 van and theres still about 5 inches gap between the tyre and the arch
Old Jul 17, 2007 | 10:46 PM
Series 1 van's Avatar
Series 1 van
what i did is take axle off cut base plate off for leaf to sit it a locater cut it if rest axle on top ov it then get messurements rite then weld them back on and ive put inch lowering blocks on off a mk2 escort
Old Jul 17, 2007 | 11:55 PM
rsvan's Avatar
rsvan
Old Jul 18, 2007 | 09:56 PM
Series 1 van
when i put cossys escorts on mine lowered had to hack arches to bits took days to sort out but the s1 arches hid it i had 195 40 16 a think on them were a tight fit as well
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
fatboy billy
Aug 3, 2015 08:34 AM
