intercoolers
Old Jan 15, 2004 | 07:31 AM
Default intercoolers
could someone please explain to me what the difference is and advantages of 4x4 and 500 intercooler over a 2wd one
Old Jan 15, 2004 | 09:36 AM
Guinnless's Avatar
Guinnless
Greater efficiency. More power.
HTH
Old Jan 15, 2004 | 12:50 PM
Switch's Avatar
Switch
as above and they are bigger!!!!
Old Jan 15, 2004 | 02:43 PM
as i am thinking of going for a 330 or maybe 400 bhp engine which would i need
Old Jan 15, 2004 | 03:29 PM
PJay's Avatar
PJay
for 330 a 4x4 will do, anything over that and i'd say go for the rs 500 cooler.
PJay
Old Jan 16, 2004 | 06:06 PM
RSCossieGaz's Avatar
RSCossieGaz
so a standard 4x4 cooler is ok to still be used if your going for a stage 3?
Old Jan 16, 2004 | 07:48 PM
yes mate 4x4 will be fine but if you put the rs500 cooler into that same spec car you would get a bit more power out of it due to better cooling of the charge air!
Old Jan 16, 2004 | 11:09 PM
dave cos4x4's Avatar
dave cos4x4
RS 500 type if you can afford it!
Dave.
Old Jan 17, 2004 | 07:05 AM
AlexD's Avatar
AlexD
Post Miester !
Just put and RS500 Type in mine, much better
Old Jan 18, 2004 | 03:41 PM
foreigneRS's Avatar
foreigneRS
Testing the future
depends on the boost level, size of turbo, ambient air temperature, speed, etc, etc. you might not get any benefit for 90% of the year, only more lag as the turbo will have to pressurise a larger inlet volume.
i would start with a 4x4 one, get an act or secs monitor and check it. 4x4 i/c 50 quid, rs500 type couple or 3 hundered quid. plus the rs500 type will have bigger pipework normally used with a t4 size inlet turbine so you might also need new hoses or adaptors if you're going to use a t3 only (330 max)
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
