cvh efi mfi questions
Old Jul 13, 2007 | 04:22 PM
Moondust_crust's Avatar
Moondust_crust
Default cvh efi mfi questions
hello peeps, im building a cvh turbo engine for the cabby, bought one off here which has had some work done to it but its mfi , and the cabby is efi.
can i just put a efi inlet on it with a conversion plate from ferriday engineering or is there more work involved, what do i need to do to convert it to efi? also what ecu should i run it on? any help gratefully recieved.
cheers mark.
Old Jul 13, 2007 | 09:18 PM
MarkN's Avatar
MarkN
You don't need a conversition plate at all - just put your EFi head on the MFI engine its a straight swap.
Old Jul 14, 2007 | 03:22 PM
xrmalin's Avatar
xrmalin
I think ive read this right but you need an efi head as the ports are a differant shape but if you've still got your engine out the cabby you can use the head off that as the efi xr & rs heads are the same.
mk3ste
Oct 17, 2021 10:09 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
