Draining coolant Escort Si mk6
Hi,
After a little bit of help I'm wanting to change the coolant in my car but can't seem to find a hose to drain from.
Can anyone give me some advise as to the easiet way of draining this please
Escort Mk 6 1996
Many thanks
Escort Mk 6 1996
Many thanks
When i replaced my Thermostat i did it the bodge way lol
I Literally unscrewed the thermostat housing off the side of the engine and had a large bowl underneath the car. The coolant all then poured out of the housing and I aimed it into the bowl.
Was a little bit messy, nothing bad though, just spilt a bit over the gearbox.
Probably is a proper way to do it, but im not the most mechanically minded person, but that worked fine
Originally Posted by bluescortcossie
from experience i wouldn't bother with the drain plug , every time i have tried the threads have stripped , just take of the bottom hose
Adam Graham
Sep 6, 2015 06:04 AM
