rs turbo head help
Old Jul 11, 2007 | 09:46 PM
M1CH43L's Avatar
M1CH43L
Default rs turbo head help
evening ladys and gentilemen, i can get hold of a rs turbo head thats got solid lifters big valves and a wild cam,
what im wondering is would this be ok on a standared bottem end??
the reason im asking because me mate sold a bottom end that was all steel so i lost out
edit;
iv just been told its good lol cheers for looking
Old Jul 12, 2007 | 08:17 PM
homer j's Avatar
homer j
the only reason for useing an all steel bottom end is for strength. the standard rods don't like much more than bout 20 psi boost and so tend to be converted. unless the valves touch the piston tops the head should be fine. it probably won't realise it's full potential though without being able to run big boost but should still produce good results. hope that helps
Old Jul 12, 2007 | 08:38 PM
105epwr's Avatar
105epwr
as above,but also a "wild" cam will rev in excess of 7k but rev limiter on a rst is 6.5k and rods wont like 7kplus.if its wild enough it wont probaly come on song untill 4-5k then hit the limiter at 6,5k!i run a standard cam and 242bhp and 272lbft SCS recomended this to me.
Old Jul 13, 2007 | 08:10 PM
M1CH43L's Avatar
M1CH43L
ooh reet cheers to both of you
as for the boost iv been told 13psi is about a good safe ish boost pressure
oh and i have a t3 for it if that helps
Old Jul 14, 2007 | 02:03 AM
SafeChav's Avatar
SafeChav
Can i just ask the reasons behind wanting a CVH head with big valves, solid lifters, a "wild cam" as you put it to run with a standard bottom end and especially running only 13psi of boost?
Complete and utter waste of time mate
Old Jul 16, 2007 | 09:33 PM
M1CH43L's Avatar
M1CH43L
arr but that was my question lol mr safechav
Old Jul 17, 2007 | 10:53 AM
SafeChav's Avatar
SafeChav
Well im asking you........
Thats a good £700+ worth your planning to spend, and if anything, it will make the engine worse to drive. You only need massive valves and stuff like that when you are wanting to run some serious power.
13psi of boost and a standard bottom end isn't a good combination to run with a top end spec like that!!
SmudgerByName
52
Jul 28, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
IAN RS2k
Aug 18, 2015 07:51 PM
