rst series2 pinking
Old Jul 8, 2007 | 02:08 PM
daveselwood's Avatar
daveselwood
Default rst series2 pinking
cant get rid of pinking noise,car has colloins chip -31 actuator running 15psi,what should the timming be set at please
Old Jul 9, 2007 | 10:53 PM
SafeChav's Avatar
SafeChav
Who knows??
Depends what chip its got/how the ignition map is set.
Probably going to be a rolling road jobby. You could try retarding the timing slightly incase the dizzy has been off and has been advanced slightly more when upon refitting, but if its anything too significant leave it to a tuner.
Old Jul 11, 2007 | 09:10 PM
105epwr's Avatar
105epwr
want to run around 10-12" on the timing strobe @900rpm with the vacum pipe to the ecu(take it its on mfi)blocked using 98 ron fuel then adjust you c0 to about 1.5%co @ idle should be ok
Old Jul 12, 2007 | 11:23 AM
SafeChav's Avatar
SafeChav
Not necessarily if its chipped.......PWM mod chips can make them run massively retarded ignition at idle.
Old Jul 12, 2007 | 07:42 PM
105epwr's Avatar
105epwr
SCS set mine up to that wen i was running a 195 chip and pulled 180bhp at the wheels at 17psi
Old Jul 13, 2007 | 12:48 PM
SafeChav's Avatar
SafeChav
yea but it depends on what chip he has and/or how its mapped.........
Old Jul 14, 2007 | 10:41 PM
Series 1 van's Avatar
Series 1 van
try optimax petrol
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
`spotty
Sep 25, 2015 11:41 PM
Billy_RS
Sep 13, 2015 04:17 PM
