does this spec sound anygood/strong?
Old Jul 3, 2007 | 09:07 AM
fast_ford_uk's Avatar
fast_ford_uk
Default does this spec sound anygood/strong?
2.1 Zetec Turbo Engine - 8.2:1 Compression Ratio - 15-18psi boost
Forged Vauxhall XE Pistons
Modified Con Rods to take the above
Focus Tripple Layer Steel Head Gasket
0.5mm Ally Shim bonded to head
ARP Rod Bolts
All new Rings, Seals, Bearings
Front Breather blocked, two fitted on the rear
Breather oil return fitted to rear of sump, and turbo oil return on the front
New water pump
The Block was bored out to take the pistons, and crank polished as it did not need a grind
Modified cam cover giving second breather, powdercoated black
Fully Reconditioned head, drilled and tapped to take t3 manifold
T3 & Manifold included,
Also ;a 4 paddle, megasquirt1 v3 board ,innovate lc1wideband lambda sensor kit, 370cc side fed injectors, Powder Coated Efi Inlet Manifold, Breather Pot,
_________________
Old Jul 3, 2007 | 12:38 PM
IANS2RST's Avatar
IANS2RST
not really, you've got standard rods, vauxhall pistons & a decompression plate
Old Jul 3, 2007 | 02:18 PM
JesseT's Avatar
JesseT
Default Re: does this spec sound anygood/strong?
A minor detail, but the Focus 4-layer gasket is 0.5mm thicker than the 3-layer version, so there is no need to play with ally shims.
Old Jul 3, 2007 | 07:38 PM
fast_ford_uk
ok, its not mine but i could get it
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
